🎉Community Raffle - Win $25
Join and Win
Problem with Crasurv
Hi,
I'm trying to understand LAW 25 with CRASURV formulation. So I perform a single element test to see how it works. As far as I can see from the Radioss Reference Guide, it should be possible to use different values of plastic work for each material direction by setting the Flag Iflawp=1. So I do that, but there was no effect. The global criteria (Wpmax) was still the dominating one and the local one (Wpmaxt1,Wpmaxt2,.....) has no effect. That means, the Element is ruptured when the global criterion is reached. If I deactivated the global criterion the local one also has also no effect, which means that the element is not ruptured.
What do I wrong?
best regards
1 - 10 of 101
