🎉Community Raffle - Win $25
Join and Win
*** INTERNAL PROGRAMMING ERROR # 8006 ***
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi, I'm getting the following error while trying to run a modal analysis in Optistruct. Could anyone help me make sense of this?
ANALYSIS RESULTS :
ITERATION   0
 *** ERROR # 825 ***
 The run will be stopped due to the previously encountered fatal error
 from the element generation routine in preprocessing:
    Number of failed elements = 1
  Last encountered error code = 15
 The previous error is encountered in subroutine prpdrv.
 This error is issued in subroutine elqcdrv.
 Data block effmas not in data manager dictionary.
 * DATAMANAGER ERROR in subroutine 'locateit'.
 ****  Error 8006 in datamr() during 'locate' operation.
     Data block name 'effmas'.
     Current memory allocation  8166 MB,
    Unused memory              6248 MB,
    Number of blocks: 280 used, 5 free.
     Call arguments 0, 0.
 *** INTERNAL PROGRAMMING ERROR # 8020 ***
 Failed database modify command:  Locating array effmas.'
 * DATAMANAGER ERROR in subroutine 'LOCATE'.
 This error occurs in module 'wrtdrv'.
