Rupture of composite laminates
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
hello all,
will you please tell me, which engine card i should use to see fiber failure, rupture and delamination of composite laminates
Welcome!
«1
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    and i am not able to see 3D representation of ply thickness, orientation when i do FE modeling for Radioss
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    HI Rahul,
    In RADIOSS it is not possible to visualize the plies as can be seen in OptiStruct.
    There are few failure models available (/FAIL) for composite. Please refer to those models.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Thank you so much.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    how can i see Strain energy in hyperview?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hi Rahul,
    You can output Strain energy using Control cards>>ENG_ANIM_ELEM>> EPSP.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    thank you:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    It is working now. But still it is not giving option to see strain energy in hyperview
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hello prakash,
    i have created my composite plate using- Material: M25_COMPSH and Property: P11_SH_SANWD
    now i have to use PUCK criteria for impact analysis. where i should define or assign FAIL/PUCK?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Rahul,
    Create a property with type as FAIL/PUCK.
    I will get back to you with Strain energy soon.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    ok but in addition i have to define plies using  Material: M25_COMPSH and Property: P11_SH_SANW.
    so my question is how can i use both the properties-- P11_SH_SANDW and FAIL/PUCK for same component
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hello Prakash
    will you please reply to my above question?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hi Rahul,
    Introduce the /FAIL/PUCK property and refer the material in the new card.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    ok i will do it
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    I am not getting how to assign FAIL/PUCK.
    Please help me.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    i will try one more time and then i will get back to u
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    i am not getting
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Rahul,
    can you share the .out file?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    can you check the Tau Max value?
    Normal value of Tau Max is 10 times higher than the actual times step should be set in the card directly.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    that's okay. but i am struggling to introduce FAIL/PUCK property. I am not able to assign it to component 'XYZ'. i hve already defined comp. 'XYZ' using  Material: M25_COMPSH and Property: P11_SH_SANW.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Rahul,
    you dont need to assign to any component. Refer the M25 material in the fail/puck property
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    okay thank you. i will run it
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hi Prakash,
    Composite plate is ruptured as shown in pics. But how to see fibre and matrix failures in small particles?
    Thanks & Regards,
    rahul
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    And ruptured elements are getting deleted. is there any way to stop it?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2016
    Hi Prakash
    You are supposed to tell me about strain energy?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2016
    Hi Prakash
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Rahul,
    I am checking with experts on how to output strain energy for composites. I will get back to you soon on this :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    Altair Employee
    okay i will wait
  • Altair Forum User
    Altair Forum User
    Altair Employee
    You can get the output in animation file with /ANIM/ELEM/EPSP
     For Law25 this output is plastic strain energy. It is equal to zero when the material is elastic
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Sorry here EPSP gives the plastic work.
Welcome!
Welcome!
