INTERNAL PROGRAMMING ERROR
Hi,
I am doing Nonlinear Geometric analysis of a plate spring model. It errors out as
*** INTERNAL PROGRAMMING ERROR # 8011 ***
DELETE detects overwriting of data block: elmres.
* DATAMANAGER ERROR in subroutine 'datamd'.
Re-checking all lenvec buffers
Data MARKER at 1 found 0 expected 2146697216
Data MARKER at 2 found 0 expected 2146697216
What is this error? Please do help me in solving this issue.
Hi Prakash,
I am using shell and solid elements with contacts.
I too have used spring element to overcome the convergence issue( The run didn't start without spring element)
Its a large displacement problem.
Hello,
I am using NLSTAT, but I have the same errors.
DELETE detects overwriting of data block: plsgau.
*** INTERNAL PROGRAMMING ERROR # 8008 ***
CHECK detects overwriting of data block: plsgau.
* DATAMANAGER ERROR in subroutine 'datamx'.
Array 'cs2sres' was the first in memory after this array.
Thank you in advance
KBE
Hi @Karthic
Can you please let us know more about the analysis, elements used, etc..?
If you are using NLGEOM analysis type for small strain problem, then please switch to NLSTAT and try again.
