Spacing optimization
1 - 4 of
41
By spacing optimizaiton I mean determining the number and location of ribs, i.e. proper spacing of the ribs.
To clarify what you are suggesting, you are saying to run a topology optimization on the ribs globaly, utilizing pattern repition. Then just look at the results from the stress analysis to determine which ribs are necessary. Is this correct?
Hi Davewalker,
could you please explain what do you mean by spacing optmization?
If you are looking to check if any ribs can be removed from the design space, best method is suggest him Pattern Repetition from topology optimization.
Just running topology with compliance would be best method to know if some ribs can be removed.
check the stress distribution in those ribs if they are not taking much load it can removed.
