Optistruct Convergence Settings
User: "exx077"
Altair Community Member
Updated by exx077
Hello,
I am running a topology optimisation using Optistruct. The results I am getting for a standard min. compliance, constrained volume fraction run without any manufacturing constraints are invalid. The simulation runs but the results do not show any clear structural members but mostly very low density material.
However, when I use minimum member size control, extrusion constraints and change the discrete value the results achieved are valid (show structural members).
Is there a way to chance the minimum convergence parameters to encourage the solution to find a valid structure for on optimisation without manufacturing constraints.
Thank you in advance
1 - 8 of 81
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @exx077
    Usually, results without manufacturing constraints are best results but not manufacturable.
    Did you try to change the ISO value in HyperView?
    Is it possible to share the model file?
    User: "exx077"
    OP
    Updated by exx077
    Hi @Prakash Pagadala,
    I have had a look at the iso result on Hyperview. This is how I can tell there is lots of low density material (<0.05). There are only 8 iterations, which is what makes me think that there may be insufficient convergence.
    Density>0.05 for VF=0.05 (left) and 0.075 (right)
    <?xml version="1.0" encoding="UTF-8"?>density0_05.thumb.jpg.3e9256b4ef3778df249184e690590199.jpg
    Density>0.1 for VF=0.05 (left) and 0.075 (right)
    <?xml version="1.0" encoding="UTF-8"?>density0.1.thumb.jpg.56f67cdaf1db9cea1f7004badbf441a4.jpg
    HM file:
    des.H3D file:
    Thank you
    Altair Employee
    Hi,
    PFA results
    User: "exx077"
    OP
    Updated by exx077
    Wow, these results look great!
    However, I do not understand what they are showing.
    Does PFA stand for Progressive Failure Analysis?
    If so, do the regions or high density show where probability of failure is highest?
    Thanks
    Altair Employee
    PFA( Please find attached results)
    The results show optimal material layout. Red being the highest material density.
    User: "exx077"
    OP
    Updated by exx077
    @Prakash Pagadala,
    I see, thank you.
    What optimisation parameters have you used?
    The square panel regions are really impressive.
    Thanks
    Altair Employee
    I will share the model with you
    User: "exx077"
    OP
    Updated by exx077
    Great, thanks again @Prakash Pagadala
