🎉Community Raffle - Win $25
Join and Win
Mfluid element mass repartition :OS-V: 0460 Dynamic Behavior of a Fluid-containing Structure using MFLUID
User: "Insaf Mohamed Rizan"
Altair Community Member
Updated by Insaf Mohamed Rizan
I have been using the benchmark model appearing in your guide for some simulations.
However there are some points that I would like to clarify with your support on these models to get a better understanding of the Mfluid element available on your package.
My question is regarding the Mass matrix outpu.Indeed when we simulated we observed that the mass is lower in the Z direction  than the 2 other directions, even when you have a 100% fill.
How is this possible? Is there any theoretical explanation for this ?
Thanking you in advance
1 - 3 of 31
    User: "Xiaolei"
    Altair Employee
    Updated by Xiaolei
    Hi Insaf,
    Can you let me now how you checked the mass matrix of virtual mass alone? As long as I know OS only supports DMIG for the entire model(structure+MFLUID).
    Can you also check partial filled let's say with a height that is smaller than radius of the cylinder?
    Thanks.
    Xiaolei
    OP
    Hi Insaf,
    Thanks.
    Xiaolei
    Hello Xiaolei ,
    You can add the following params to get the fluid mass matrix output:
    PARAM,CHECKEL,NO
    PARAM,EFFMAS,YES
    PARAM,GRDPNT,15969
    PARAM,VMMASS,YES
    PARAM,VMOPT,1
    I have tried for different fill levels and you get the result in the output file
    User: "Xiaolei"
    Altair Employee
    Updated by Xiaolei
    Hello Xiaolei ,
    PARAM,CHECKEL,NO
    PARAM,EFFMAS,YES
    PARAM,GRDPNT,15969
    PARAM,VMMASS,YES
    PARAM,VMOPT,1
    I tried with a 25% fill level(the one on the right side), then the pass in P1 and P2 is much smaller.
    I don't have the formula of this directional mass calculation at hand, but I think this change should make sense.
