Raw Gap Opening
New Altair Community Member
Updated by Joel Rodarte
Helllo, I have been using CNTPRM with PREPRT toggled on.
This generates .cpr file with the satus of my contacts
What is RawGap? The small description is not very clear or illustrative, do you have another explanation?
Thank you!
1 - 2 of
21
OPUpdated by Joel Rodarte
Rawgap is the physical gap between two midsurface.You could refer to below TTF for print contact info prior to analysis.
Did you define any CLEARANCE? Which version OptiStruct Solver you are running?
I am Using 2017 Version.
The thing is that i am NOT using midsurface for this model :O Just 3D elements.
No, I did not declare any clearance. Wha tdo you think about it?
https://insider.altairhyperworks.com/wp-content/uploads/2018/10/TT-1329-OptiStruct-Print-contact-info-prior-to-analysis.pdf
