run execution time parameters
Adela
Adela Altair Community Member
edited August 2023 in Community Q&A
I'm currently following a tutorial and I can't find where to set " run execution time parameters" in Simlab 2022.3.
Can anyone tell me where to set this parameter in simlab 2022.3 ?
Thank you
Answers
  • Santhoshkumar
    Santhoshkumar
    Altair Employee
    edited July 2023
    Hello,
    This option is moved under "Create solution" dialog. Go to "Solutions > Applications > Drop Test".
    Thanks & Regards,
    Santhoshkumar
  • AlessioLibrandi
    AlessioLibrandi
    Altair Employee
    edited August 2023
    Additional note: if you want to edit this parameter after creating the solution, please just double click on the solution name.
Welcome!
Welcome!
