I'm currently following a tutorial and I can't find where to set " run execution time parameters" in Simlab 2022.3. Can anyone tell me where to set this parameter in simlab 2022.3 ? Thank you
Hello,
This option is moved under "Create solution" dialog. Go to "Solutions > Applications > Drop Test".
Thanks & Regards,
Santhoshkumar
