Hi
If you are setting the model for Radioss, there is not possible to offset the midsurface plane to one of the externa or internal surface within the /PROP/TYPE1.
You will need to mesh the part considering the midsurface location, or offset the mesh.
One option is if you were using composite property, like /PROP/TYPE11. Within this you can offset .
I hope this information is helpful
Regards
Thank you very much.
I have one layer of solid elements between the two layer of shell elements
- meshing the part considering the midsurface location, or offset the mesh: I think the thickness of the solid element will be higher than it actual thickness
- /PROP/TYPE11 is not compatibilible with MAT2 what I would like to simulate.
Do you have any suggestion?
Hi
Regards
