🎉Community Raffle - Win $25
Join and Win
Difference between 2D and 3D composite material assign
Hi guys,
Im currently working in composite modelling.
So basically in 3D we model the composite plys as a single layer of 3D element regardless of material orientation and the number of ply layer. In my case, I am using (carbon fibre reinforced epoxy-CFRE) 4 layers of carbon fibre with epoxy as the matrix. Therefore, I can just apply a single material properties obtained from the tensile test of the combined material and assign the material under the PSOLID property.  Am I correct about this statement?
And in 2D modelling using the hypercomposite we are able to arrange the plys sequence and orientation. But how are we going to apply the material properties for each ply? can I use the material properties data obtained from the tensile test of 4 layers carbon fibre or I have to do tensile test for 1 layer of carbon fibre and assign the data to each ply?
I'm confused about this. Please help.
1 - 8 of 81
