🎉Community Raffle - Win $25
Join and Win
Error code: 9 Error code: 1 import template not found external reader not found
User: "przemyslaw.bolisega1"
New Altair Community Member
Updated by przemyslaw.bolisega1
Hi pals,
I'm struggling with this problem:
Error code: 9
Error code: 1
photos are attached below so you can see better what i mean. I'm trying to install educational version of HyperWorks pack 2019. It's seems to working at all but i don't know to trust it. I can import model and do some changes, I can add mesh and so on but i don't know if there would be any limitation in further actions. I plan to make some linear static simulations with mixed elements and I plan to optimize my design with Free-shape optimization. There were several issues like inability to import models or even open models, almost everything was gray but it seems that reinstall helped for this in some way. Please help me!
The things i tried is:
reinstalling with removing everything from PC
reinstalling to another partition
adding environmental variable
moving license file to correct folder
license file is not empty
turning off antivirus
I open through start appplications - desktop applications doesn't seems to create at all, there is only HyperView Player 2019 on desktop.
PC configuration:
AMD R9 280x
16GB RAM
x64 win 8.1
i5 4690k
so i think there would be everything fine
1 - 14 of 141
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Your installation is really weird. In general, the software will be installed in  C:\Program Files\Altair\2019\ ... yours is in C:\Altair\....
    My only advice: uninstall everything and try again.
    OP
    Is is really necessary to install it on C:\Program Files\Altair\2019\... ???
    I don't know, but I never modify this path. And more important, Hypermesh works very well on my PC :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    User: "PrasannaK"
    Altair Employee
    Updated by PrasannaK
    Hi,
    Kindly make sure after downloading the license file, rename it to altair_lic.dat and place the same in the <installation directory>/security folder. Crosscheck the name of the file; it  should be 'Altair_lic.dat' and not 'Altair_lic.dat.dat'.
    Also make sure the Ethernet id for which the software has been requested is correct. If not, then request for another license file for correct Ethernet id here:  https://studentedition.altair.com/
    The node limitation for OptiStruct is 100,000 nodes for Student Edition. You can more information here: https://altairuniversity.com/altair-student-edition-limitations/
    Thank you
    OP
    Done and nothing changed. I tried several combinations of installing, I mean skipping license file and so on.
    Hi,
    Thank you
    name is altair_lic and format of file is .dat. Ethernet id is checked and is correctly applied in license
    Overall, nothing changed. Still have the same warnings/errors. Does somebody know what to type in field ,,Account:' in Altair Connect support request system? Totally have no idea, I tried almost everything and the field seems empty and don't want to accept my typings. It also saying no request Access.
    Do you check  'MD5SUM' all downloaded files?
    OP
    I don't have any reference to compare my md5sum code. I have a student pack and i don't see there any option to show how should look md5sum code. Any ideas?
    Have a look at the following screenshot:
    <?xml version="1.0" encoding="UTF-8"?>altair_download_checksum.thumb.png.821e3e3af02819318528e0c4bb56a3b8.png
    OP
    I have a student license so i have only a link to direct downloading.
    Sorry, I can't help more.
    Maybe ask ALTAIR's support?
    User: "QuentinL"
    Updated by QuentinL
    Hello,
    I have the same problems with my student version. When I open HyperWorks this message appears and it suddenly closes the app. I tried to download it several time but it's always the same.. Someone have an idea please?
    Thanks for answering!
    User: "Jan Grasmannsdorf_20379"
    Updated by Jan Grasmannsdorf_20379
    Hello,
    this error occurs, when you have a 'full academic' or 'full commercial' license on your computer (e.g. from a previous installation or previous license from a university or company). The student edition will not show this error, when you have ONLY the Student Edition license. To check for your second license, you can do the following steps:
    1) Check for a local license file:
    Go to the 'Environment Variable Settings' of your installation and see, whether there is a variable 'ALTAIR_LICENSE_PATH' which hints to a local license. If so, please delete this environment variable or rename or delete the license file to which it hints.
    After that, Save the correct Student Edition 'altair_lic.dat' file  to the '../security folder of your Student Edition Installation.
    2) Check for a 'Hosted HWU License':
    Maybe you still have a reference to an Altair Hosted License, which will be checked on startup of the Student Edition. Please go to:
    C:\Users\<yourusername>\AppData\Local\.altair_licensing\DEWLT455\ and check if there is a '*.cfg' file. If so, please delete this config file. This removes the 'Hosted HWU' License on your computer.
    Please note that the 'AppData' directory is a hidden directory - you have to activate Windows to show your hidden directories in your system settings first.
    After the deletion of the cfg file, please save the correct altair_lic.dat of your student edition to the ../security folder of your student edition.
    Best Regards
     Jan
    OP
    Do not work :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' /> I tried also by removing all data and also by reinstalling my whole system from new.
    Hello,
    <?xml version="1.0" encoding="UTF-8"?>grafik.png.679b1dd17aeee2c4e65652aed81c5a5a.png
    <?xml version="1.0" encoding="UTF-8"?>grafik.png.ebd11625148f48885d022175af33b781.png
    Best Regards
     Jan
    User: "QuentinL"
    Updated by QuentinL
    Do you have special characters in your username ?
    If that is the case, it is certainly due to that.
