🎉Community Raffle - Win $25
Join and Win
What units should I choose? How can I read the analysis results correctly?
User: "Betül Özer"
Altair Community Member
Updated by Betül Özer
Hello, I selected gram, mm, ms and N units in the Hypermesh program. I could not understand what the unit of the first frequency value that came out of the modal analysis was. I attach the picture of the analysis result. I would be very happy if you could say numerical values ​​together with their units.
I'm still not very good at studying units and analysis results. I hope I will learn :)
Actually, I have one more question. I want to choose my units ton, mm, s and N. But there is no undertone of hypermesh either. Or I don't know. He will be very happy if you help. I am adding the relevant images.
Regards,
1 - 5 of 51
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    the unit of the frequency value is Hertz (Hz), which is also defined as cycles per second (s-1).
    A very small (near 0) frequency value indicates a rigid body mode.
    The tonne unit is MGG (megagram) in Hypermesh.
    User: "Betül Özer"
    OP
    Hi,
    Thank you, so when I select tonne (mgg), N, mm and s, will i read in MPa on my result screen?imageFor example is this 43.62 MPa?
    User: "Betül Özer"
    OP
    Hi,
    imageIs this 82.8214 Hz? (I select mgg, N, mm and s)
    Glad to help.
    Following tonne (mgg), N, mm, s units should give MPa.
    Always follow a consistent set of units:
    https://www.altairuniversity.com/wp-content/uploads/2012/04/Student_Guide_55-57.pdf
    Yes, the frequency units are always Hz.
    You need to make sure to use consistent units for stiffness and mass in order to get the correct frequency result.
