What units should I choose? How can I read the analysis results correctly?
Hello, I selected gram, mm, ms and N units in the Hypermesh program. I could not understand what the unit of the first frequency value that came out of the modal analysis was. I attach the picture of the analysis result. I would be very happy if you could say numerical values together with their units.
I'm still not very good at studying units and analysis results. I hope I will learn
Actually, I have one more question. I want to choose my units ton, mm, s and N. But there is no undertone of hypermesh either. Or I don't know. He will be very happy if you help. I am adding the relevant images.
Regards,
