🎉Community Raffle - Win $25
Join and Win
How to fix rotating center?
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hi,
When I operate the model, it always change the Rotating Center when I rotate model by Middle mouse on the model.
May I know how to fix rotating center of model?
1 - 3 of 31
    User: "Santhoshkumar"
    Altair Employee
    Updated by Santhoshkumar
    Hi,
    Middle mouse button click will fix the rotation center. Please refer the attached image.
    User: "AlessioLibrandi"
    Altair Employee
    Updated by AlessioLibrandi
    You can not fix the rotating center using the mouse. Every time you middle click to rotate, this will select a new rotating center.
    What you can do if this disturbs you is:
    - use a 3D space mouse: in this case, the '2D'mouse middle click will  fix the rotation center, the 3D mouse will do the rotation
    or
    - choose under File|Preference|System a different Mouse setting. FOr example, 'Hyperworks 13.0' allows to choose the rotation center and rotate separately, like in Altair HyperMesh.
    User: "alpha_21885"
    OP
    Thanks Alessio for your solutions.
    So, if I want to separate Rotation Center and Rotation, I will use HM setting.
