🎉Community Raffle - Win $25
Join and Win
Submodeling
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello
I am working with a large assembly I want to perform Frequency response analysis on this large assembly
so can i use Submodeling approach for this to save my time and concentrate on a particular component in assembly?????
i googled the topic i found that submodelling is mostly related with Free body diagram so is it possible to capture the stiffness of other component?
and use Submodeling for modal or Frequency response analysis????
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    SUBMODEL (only works with linear static subcases)
    Regards
    Rahul R
    Altair Employee
    OP
    Hi Sagar Desai,
    If you are not talking about SUBCASE specific submodelling, then yes you can use Meshing submodelling approach for FRA. But I would suggest you to go through few already existing papers and projects.
    What I got to know is using submodelling will anyway reduce the computing time but this will introduce artificial high frequencies. So, validating results is up-to you (Analyst).
    Altair Employee
    OP
    thank you for help
