- _JAVA_OPTIONS=-Xmx512M
- JAVA_TOOL_OPTIONS=-Dos.name=Windows 7
- JAVA_TOOL_OPTIONS=-Dos.name=Windows 7 (Line 19)
- Path=C:\Program Files (x86)\Common Files\Oracle\Java\java8path;C:\Program Files (x86)\Common Files\Oracle\Java\javapath; (Line 25)
- _JAVA_OPTIONS=-Xmx512M (Line 49)
Hello,
Could you please type the following command in the command window? This will generate the text file in the user folder. Please send the text file. We will check and get back you.
Thanks & Regards,
Santhoshkumar
thanks for repling.
i try to add two envirorment variable,like below
and update java software but all fail.
thanks for repling.
Hello,
Could you please remove the following variables and check?
Please don't rename. Remove the above variables and check. After removing the above variables, if it works. Then, we will check further.
Please check and let me know.
Thanks & Regards,
Santhoshkumar
Hello,
Thanks & Regards,
Santhoshkumar
Thank you so much for your assistance, I really appreciate it!
May I ask if you are an engineer from Altair?
If I have related questions in the future, how can I contact you? Is it possible to reach out via email?
Hello,
Glad that you can successfully install SimLab after removing the variables.
Yes, I am part of Altair team and I am taking care of the quality assurance for the SimLab software.
Sure. Here is my email ID (sants@altair.com). Feel free to reach me.
Thanks & Regards,
Santhoshkumar
Hello,
Thanks & Regards,
Santhoshkumar
thanks alot!!!!!
Hello,
Thanks & Regards,
Santhoshkumar
