Does PreStressed Modal Analysis considers the FEA results of previous nonlinear analysis results?
DGK
DGK Altair Community Member
edited May 2022 in Community Q&A
Below given are few cases:
Case 1:
Step 1 is Bolt preload
Step 2 is modal analysis STATSUB(PRETENS)=previous step
Case 2:
Step 1 is Interference Fit
Step 2 is Modal Analysis
Kindly guide me if there is any appropriate documentation available.
Best Answer
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited May 2022 Answer ✓
    For modal analysis you can use STATSUB(PRELOAD) option to carry stiffness change due to preload into your loadstep.
    Take a look at OptiStruct help for Preload.
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
Welcome!
Welcome!
