🎉Community Raffle - Win $25
Join and Win
Organizer error "Library is closed" and crash
User: "Niccolo'  Bigagli"
Altair Community Member
Updated by Niccolo' Bigagli
I tried them all, but when i open hyperworks desktop and i switch to hypermesh i recive the organizer error "library is closed" and the software crash. I found out in the forums other problems like this one, so i removed setting's temporary files. FIrst i recived organizer error "library is closed" when i started hyperworks desktop, next i removed in the properties the destination after the "C:\Users\Niccolo'\Desktop\Altair HW\hwdesktop\hw\bin\win64\hw.exe" and now i can open hyperworks desktop. the problem appears when i switch to Hypermesh and the programm crash. I tried them all to solve it, but it doesn't work. I have the studente version.. how can i solve my problem?
1 - 3 of 31
    User: "Viraj_Kulkarni"
    Altair Employee
    Updated by Viraj_Kulkarni
    Can you please delete all the files in below location:
    C:\Users\%UserProfile%\Documents\command.tcl
    C:\Users\%UserProfile%\Documents\command1.tcl
    C:\Users\%UserProfile%\Documents\hmmenu.set
    C:\Users\%UserProfile%\Documents\hmsettings.tcl
    C:\Users\%UserProfile%\Documents\hwsettings.xml
    C:\Users\%UserProfile%\Documents\hwsettings.xml.bk
    C:\Users\%UserProfile%\.Altair
    C:\Users\%UserProfile%\AppData\Local\Altair
    C:\Users\%UserProfile%\AppData\Local\.altair_licensing
    C:\Users\%UserProfile%\AppData\Local\Temp\.altair
    C:\Users\%UserProfile%\AppData\Roaming\Altair
    C:\Users\%UserProfile%\AltairLibraries
    Let me know if that solves your problem.
    User: "Scarlet Mee"
    Updated by Scarlet Mee
    Hi there,
    I am also having the same problem now but I have deleted the first section of files However, I cannot find the second half of files. Is there any other way to fix this problem?
    User: "Adi23"
    Hi,
    I too am facing the same issue even after deleting the files mentioned above. Is there any other solution for this?
