Complex eigenvalue post non linear analysis- analysis steps
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm doing a simulation with Optistruct on a brake system and I want to perform a non linear quasi static analysis with frictional contact first and a complex eigenvalue analysis accounting for the frictional interaction then (i.e. asymmetric terms on the stiffness matrix).
I also read all the relative posts on this forum, but i'm still having problems. Do you have any suggestions or procedure to set the two analyses?
I have another question: in my model there are: a force that pushes one pad against the disk and a rotation of 5 degrees that puts  the contact between disk and pads in sliding; i have these two step at the same time, but is possible to put in contact only with the force first and to rotate in a successive step?
Thank You.
