*** INTERNAL PROGRAMMING ERROR # 8008 ***
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I am getting the following error after running a calculation. I have done some research and according to that, it's because I dont have enough disk space, but I have 64 GB available in my disk. Can someone please help me out? The calculation took me about 9 hours and I have to restart it. It says that the non linear analysis was ocnverged but it didnt create a .h3d file to view with hyperview.
 CHECK detects overwriting of data block: plsgau.
 * DATAMANAGER ERROR in subroutine 'datamx'.
 Array 'cs2sres' was the first in memory after this array.
Thank you
Kind regards,
KBE
1 - 29 of 291
    Altair Employee
    OP
    Hi @KBE
    Can you share the .out file, please?
    Altair Employee
    OP
    Hi @KBE
    Hi Prakash,
     Unfortunately I can't, as it's confidential. Could you please suggest some things I  could verify in my set up? I am also getting the following error with it.
    *** INTERNAL PROGRAMMING ERROR # 8011 ***
     DELETE detects overwriting of data block: plsgau.
     * DATAMANAGER ERROR in subroutine 'datamd'.
     Re-checking all lenvec buffers
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    Hi Prakash,
    <?xml version="1.0" encoding="UTF-8"?>image.png.19ca581e141129f5bae5f0a37cadd776.png
    Hi
    Under load you have placed Disc deplacement load colletor? Does it contain force data of SPC data?
    Altair Employee
    OP
    Hi
    Hi @Nachiket Kadu
    The disc displacement is made of SPCDs.
    Hi
    You are trying to give displacement? If yes try giving it in SPC itself and then check.
    Altair Employee
    OP
    Hi
    I have done a model similar to this. The only difference is the size of the two cylinders that I am trying to encase.  I have already defined the necessary SPCs and the SPCDs for those SPCs. It worked with the first model but not working with this. I double checked all the constraints as well.
    Altair Employee
    OP
    Hi @KBE
    Can you share the list of output requested you have in your solver file?
    Also, remove NLOUT and check if that helps.
    Altair Employee
    OP
    Hi @KBE
    Hi @Prakash Pagadala,
    Is this what you meant? or did you want the output data requested in the global_output_request card?
    Altair Employee
    OP
    Yes,
    Some result outputs are not compatible with NLOUTs and may end up using high scratch files.
    It would be better if you share at least the memory required and available memory information from .out file.
    Altair Employee
    OP
    Yes,
    Did you want the information below?
    MEMORY ESTIMATION INFORMATION :
     Solver Type is:  Sparse-Matrix Solver
                      Direct Method
     Current Memory (RAM)                                    :   12498 MB
     (Note: MUMPS Solver Allocates Memory Separately.)
     Estimated Minimum Memory (RAM) for Out of Core Solution :   15048 MB
     Recommended Memory (RAM) for Out of Core Solution       :   15388 MB
     Recommended Memory (RAM) for In-Core Solution           :   23967 MB
     (Note: Memory for MUMPS Solver is Included in Estimation.)
    DISK SPACE ESTIMATION INFORMATION :
     Estimated Disk Space for Output Data Files              :     556 MB
     Estimated Scratch Disk Space for In-Core Solution       :    1396 MB
     Estimated Scratch Disk Space for Out of Core Solution   :    9975 MB
    As I am running another calculation right now, I have 46Gb still available in my main disk.
    Altair Employee
    OP
    @Prakash Pagadala,
    See below for the global_output_request card details:
    everything else is not active.
    Altair Employee
    OP
      @KBE
    clearly, the issue is with the memory and you can see this from the estimated and available memory information,
    Can you remove GAUSS stress and try again?
    Altair Employee
    OP
     Yeah i could, but it takes hours for the calculation. Should i just run it and send you the memory information?
    Altair Employee
    OP
    Tried this but there still isnt enough memory space. Is there another option?
    Altair Employee
    OP
    Hi,
    Can you share the output file (memory information from the latest)
    You can use a temporary directory to let solver write scratch files.
    Please see the link:
    And, sorry for a late reply.
    Altair Employee
    OP
    Hi Prakash,
    I tried the first two steps that you mentioned yesterday. Closing all applications running and cleaning the disk, but I still had the same issue.
    Where can I find the fixlen option? Is it in optistruct options or do I have to define it in a card?
    Currently, my collegue is using the licence so I have to wait till he is done. I will try what you said and let you know.
    Thank you
    KBE
    Altair Employee
    OP
    Prakash,
    I tried launching the calculation with fixlen but each time I enter a value for the memory, it requires more and the calculation fails. I first tried with 500, it required 540, so i entered 600 then it required 820 so then i entered 1000 and this  is what i got.
    *** ERROR # 7001 ***
     Not enough memory for preprocessing
     (total number of nonzero terms has not been determined)
     OptiStruct was executed with fixed memory size, which was not enough
     for the given run.  Please allocate more memory or use automatic memory
     allocation feature in OptiStruct.
     This error occurs in module 'prpdrv'.
    RESOURCE USAGE INFORMATION
     MAXIMUM MEMORY USED                                      1000 MB
     MAXIMUM DISK SPACE USED                                     1 MB
      *** ERROR # 7000 ***
      Not enough memory for completing the run
      current memory (in MB)  =        1000
      required memory (in MB) =        1070
    The problem is, I did a similar calculation with the exact same configurations and it worked fine.
    Regards,
    KBE
    Altair Employee
    OP
    @KBE
    Fixlen will not help.
    You need to use TEMPDIR to write out scratch files.
    Please try that and if you still face the same error, then I request you to share the .out file to report the issue with developers.
    Altair Employee
    OP
    I tried with tempdir as well and i have the same issue.
    Altair Employee
    OP
    Tried with maxlen and this is what i get.
                      Direct Method
     Current Memory (RAM)                                    :   12482 MB
     Estimated Minimum Memory (RAM) for Out of Core Solution :   15032 MB
     Recommended Memory (RAM) for Out of Core Solution       :   15372 MB
     Recommended Memory (RAM) for In-Core Solution           :   23951 MB
     Estimated Scratch Disk Space for In-Core Solution       :     584 MB
     Estimated Scratch Disk Space for Out of Core Solution   :    9163 MB
    I still see the issue with memory,
    try with -minlen
    Altair Employee
    OP
    heres what i got after trying with tempdir. It's exactly the same thing.
    For minlen, what value should I put?
    Altair Employee
    OP
    Start with 16000MB
    Altair Employee
    OP
    should I run with out-of-core instead of in-core
     Current Memory (RAM)                                    :   16000 MB
    Altair Employee
    OP
    Do you still get the error?
    Altair Employee
    OP
     yes.. i just launched the calculation with out-of-core. this might take some time. the problem with the memory space seems to be ok.
    Altair Employee
    OP
    @KBE
    Let us wait as the memory allocations seem alright, :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    Altair Employee
    OP
    @KBE
    Let us wait as the memory allocations seem alright, :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    @Prakash Pagadala,
    yeah this calculation might take some time. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Altair Employee
    OP
    hi @Prakash Pagadala
    I just checked in on my calculation and it has completed perfectly, without errors. thank you for your help
    kind regards,
    KBE
    Altair Employee
    OP
    @KBE
    That is a very good news ☺️
