Altair RISE
Nominate Yourself Now!
Freenodes and Improper set names
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
I performed modelchecker operation.
In this how hypermesh giving those freenodes as error after performing Shift+f2-> clear all.
In wat case it showing those error. How to delete it.
Secondly Improper set names how it showing.
zone_exhst_pipe2_e
zone_exhst_pipe2_n
the above two names are the improper setnames.
Below I have attached the Image.
Thanks,
mahes
1 - 8 of 81
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    Try enter panel analysis>preserved nodes>clear all preserved nodes
    about set names, I am not sure but try renaming the sets with less than 8 characters
    or remove '_' from the names
    Altair Employee
    OP
    Hi tinh,
    @tinh
    thanks tinh.
    Free nodes erased.
    But set names still not.
    I think its not length because I have bigger setnames than that in same model.
    Thanks,
    Mahes
    User: "tinh"
    Updated by tinh
    Open ...ansys/modelchecker to see what improper set names are
    Altair Employee
    OP
    hi tinh,
    @tinh
    Thanks .Will check now.
    Altair Employee
    OP
    Hi tinh,
    @tinh
    Because of the space in the set name.
    User: "tinh"
    Updated by tinh
    But you said the names are
    zone_exhst_pipe2_e
    zone_exhst_pipe2_n
    There is no space!
    Altair Employee
    OP
    Hi tinh,
    That words I typed
    In my model space is there in set name.
    Sry
    Altair Employee
    OP
    Hi,
    Thanks for the update.
    As a general remark, nodes which are not connected to a valid Ansys element are flagged in the check for free nodes, which needs to be deleted.
    For improper set names, those entity set whose name is longer than 32 characters or contains special characters other than underscore and doesn't start with an alphabet is flagged.
