🎉Community Raffle - Win $25
Join and Win
In TCL How to skip command if it dosen't have any entity to select.
User: "john stan"
Altair Community Member
Updated by john stan
Hello everyone,
I have created a sample script attached below. I want a modification in it. For example if I want to move knuckle solid in knuckle comps, but If I didn't receive the knuckle geometry from my client and I run the script. If this solid is not there to select then this command file stops and execute an error. So I want to skip the particular commands if there is no solid for selection.
*createentity comps includeid=0 name="KNUCKLE"
*createmarkpanel solids 1 "Select Knuckle Geometry";
*movemark solids 1 "KNUCKLE"
*createmark components 3 "KNUCKLE"
*createstringarray 2 "elements_off" "geometry_on"
*hideentitybymark 3 1 2
*clearmark solids 1
*createentity comps includeid=0 name="DISC"
so in the createmarkpanel if I didn't have any geometry to select .... and without selecting any geometry if I proceed it should skip the commands till createenity comps includeid=0
So if solution available please guide
1 - 5 of 51
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    you can use TCL programming syntax, such as 'if' statement.
    *createmarkpanel....
    set solids_list [hm_getmark solids 1]
    #check if the solid list is empty
    if {[llength $solids_list == 0]} {
       #do nothing
    } else {
       #do something
    also TCL catch command handles some errors wihout stopping your code.
    https://www.tcl.tk/man/tcl8.4/TclCmd/catch.html
    User: "john stan"
    OP
    Thank you for the reply Adriano,
    I tried the syntax you have given, but now with selecting the solid if I proceed and Without selecting the solid If proceed I am getting error. I use the catch command but the problem is still there.
    set solids_list [ hm_getmark solids 1]
    *clearmark solids 1
    } else {
    If any modification please do suggest.
    Altair Employee
    *clearmark solids 1
    } else {
    maybe the problem is that when you perform hm_getmark, the selection is cleared.
    Maybe you'll need to do createmark one more time based on your solids_list.
    eval "*createmark solids 1 $solids_list"
    *movemark solids 1 ...
    User: "john stan"
    OP
    Thank you Adriano.
    Actually I used If with [ ! Null ] command to solve this error. but now I got another problem.
    I get 50 to 60 solids in a hm. and I need only 16 solids from it. So I want to move remaining solids in a single component. And for that I have a criteria to mask required geometry by using their volume, surface area and COG so that only this solids can display on hm window.
    If you have any Idea regarding this please guide.
    Altair Employee
    Thank you Adriano.
    If you go to the help of HyperWorks reference guide, under 'Tcl Query commands' you will find some useful commands.
