🎉Community Raffle - Win $25
Join and Win
Analysis Error0 when I try to Analyze a structure
User: "Luca Fedeli"
Altair Community Member
Updated by Luca Fedeli
Goodevening,
whenever I try to perform an Anlysis simulation of some structure, it never ends in the right way. It pops out the message "Analysis Error0 Contact www.altair.com/customer-support".
Moreover, when I try to Optimize the same structure, it pops out another message: image
What should I do? I'm desperate while the software needs me in academic uses.
1 - 2 of 21
    User: "GTT Adam"
    Altair Employee
    Updated by GTT Adam
    Hi Luca,
    Can you share the model you are trying to do this analysis with?
    Thanks,
    Adam Reid
    User: "TonyG"
    Altair Employee
    Updated by TonyG
    Hi Luca
    To check if it is a modelling or an installation issue can you do the following.
    1. open the Demo browser (F7 or view>demo browser)
    2. open the model Baseline Analysis.stmod in the structures folder by double clicking it. This model is ready to run with all loads etc set-up.
    3. Run an analysis.
    If this model runs with no errors then the issue is probably in your model/model setup.
    If it doesn't run likely an install or permissions issue.
    Tony
