ERROR 760
Hi everybody,
I'm trying to model an head/glass impact with RADIOSS.
I've found ERROR 760, which I've read that is a generic error.
Can someone help me to find the specific problem in my model?
I can't attach the file because it's too large (maybe dropbox?).
Kind regards,
Alessio
Hi Alessio,
Please check whether /PART card image is assigned to all components or not (except rigid bodies)
If assigned and you still get the same error, please share the starter out file.
Thank you for your answers,
I've assigned PART card to all components, but the error still remain.
This is the .out file
HI,
out file is not helpful.
Please share the model file using the File transfer link in my signature.
Hi,
I can see that the problem is coming from XFEM formulation.
Ishell=1 is compatible but somehow it is not working. I will update you soon on this.
Can you use another failure instead of forming limit and check if that helps?
I see that you are using FLD failure which is for metal forming.
If you are trying to simulate deletion of elements on glass and PVB, try with MAT PLAS_BRIT, just make sure you have put in the appropriate values for epsf1 and epsf2.
Hi,
Kindly share .out files
