Duplicate SPOINT ID
User: "Uroš Rožič_22105"
Altair Community Member
Updated by unknown
Hi all,
 I am trying ot excetute the Normal models solution using Optistruct and I get this error:
 Duplicate SPOINT ID 365 - it is used on GRID card.
I went through the forum and found that renumbering migt help. I renumbered all the nodes, bit it still showed the same error.
Looking into the .FEM file, I found the node in the GRID
The node ID doesnt seeme to be duplicated.
Saddly I cannot share the file, since it is under the NDA.
All the help would be much appretiated.
Regards,
Uroš
1 - 6 of 61
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @uros
    Is it a warning or error message?
    Could you please share entire .out file?
    User: "tinh"
    Updated by tinh
    Please change GRID 365 to GRID 99999999 or max id of nodes + 1
    OP
    Updated by unknown
    Hi,
    thanks to both for the answere. I can share the .out file. It seemes there is more than one error of tis kind.
    Help is much appretiated.
    Regards
    Uroš
    Altair Employee
    Hi @uros
    One way is to renumber the GRID IDs so that the ID number of GRID shifts from ID of SPOINT.
    If you are trying to generate a DMIG h3d, you can use DMIGMOD to shift the IDs in H3DDMIG
    OP
    Updated by unknown
    hi, I amaged to solve the problem. There was an eeror with the duplicate damping elements. I deleted this elements and all went well.
    I am faced with another problem though. I have a number of 1D elements in the model some of them are RBAR and some of them are CBAR elements.I cant seeme to find the way to change CBAR elements to RBAR. I am sure it is not to difficult. Much appretiate the help.
    Thanks,
    Uroš
    User: "tinh"
    Updated by tinh
    Enter panel 1d>config edit to change elem config {bar2 to weld)
