1 - 4 of
41
Thanks, tried that discrete value, but I was hoping to also reduce the computational effort with only 1 or 0 for the thickness
I tried to figure out using the OSSmooth panel for my surface model optimization, but the iges or step file I get as a result only gives me the surface I started out with. I can't use that in CAD
there's no guarantee that your design will be discrete (0 or 1). You can try increasing DISCRETE value in OptiParam panel.
You can use OSSMOOTH panel to trasnform yor shell results into surfaces and save a CAD.
