Altair RISE
Nominate Yourself Now!
contact pressure
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Good morning
I'm making a contact analysis. Can you explain me step by step how can I have the contact pressure output?
Thanks in advance for assistance.
1 - 17 of 171
    Altair Employee
    OP
    In Control Cards>>Global Output Request>>CONTF.
    Contact output includes contact pressure and force. The contact forces can be output element by element or surface by surface.
    Altair Employee
    OP
    Good morning
    I did as you said.
    But the results do not appear the option contact pressure. Can you help me?
    Altair Employee
    OP
    Can you share the model (.fem) file?
    Altair Employee
    OP
    Ciao Giorgio,
    Grazie per la Risposta. Di Seguito si allega il Richiesto file.
    Grazie in anticipo per la Tua Assistenza.
    Altair Employee
    OP
    Puoi condividere il modello (.fem) file?
    can you help me?
    Altair Employee
    OP
    The CONTF entry is only applicable in nonlinear analysis subcases that are identified by the presence of an NLPARM subcase entry. NLPARM – Parameters for Nonlinear Static Analysis.You can create a load collector with NLPARM as card image.
    Change the analysis type in load step to non linear quasi static and in NLPARM subcase recall the load collector created with NLAPRM card image.
    Change these parameters in the input file and run the analysis.
    Altair Employee
    OP
    Thank you very much George P Johnson,
    I did as you said. In that unit of measure returns me the contact force?
    Altair Employee
    OP
    Once CONTF card is activated with NLAPRM card recalled in load step , you will contact force as output in HyperView.
    Altair Employee
    OP
    I understand, but my question is what is the unit of measurement of contact force? Because I need to have the contact pressure in MPa.
    Altair Employee
    OP
    The output unit will be based on your input unit.
    The normal unit input what we follow is Tonnes, mm, sec. In this case, the output will be MPa.
    Please find the attached image for unit consistency. <?xml version="1.0" encoding="UTF-8"?>Capture.PNG
    Altair Employee
    OP
    Thank you so much for the assistance but the contact force is a force. I would like to know the contact pressure.  Also I would like to know a method to determine the contact area.
    Altair Employee
    OP
    The elements attached to the contact surface can be found using Tool--> find--> find attached--> find--> save found.
    Then these elements can be retrieved in Tool--> 'Masc cal' panel which gives the area of the attached elements which is equivalent to the area of the contact surface.
    User: "covadonga"
    Altair Community Member
    Updated by covadonga
    Does this apply to solid elements?
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    If you request 'contf' in opti format (besides h3d), there will be a text file output with these values of force and area for each contact group, solids or shell.
    User: "FaroukM"
    Updated by FaroukM
    Only for the new release right?
    Altair Employee
    @F
    /profile/92911-faroukm/?do=hovercard' data-mentionid='92911' href='<___base_url___>/profile/92911-faroukm/' rel=''>@FaroukM I don't remember the version. At least 2019.2 already had it.
    There will be a .cntf file with force and area by contact surface, foreach load increment.
    SUBCASE       1         1 LOAD:       0     Nonlinear Load Factor:    1.000000E+00 LABEL: Caso de Carga 1
     CONTACT INTERFACE: TOTAL FORCE ACTING ON MASTER SURFACE (BASIC SYSTEM) AND TOTAL CONTACT AREA
     CONTACT#    FORCE-X     FORCE-Y     FORCE-Z     MAGNITUDE        AREA
           1    8.2880E+01  4.1754E+01 -1.7168E+05  1.7168E+05  1.5395E+04
     CONTACT INTERFACE: TOTAL NORMAL AND TANGENTIAL FORCES ACTING ON MASTER SURFACE (BASIC SYSTEM)
     CONTACT#     NORMAL FORCE     TANGENT FORCE
           1        7.1198E+04        1.0048E+05
    User: "FaroukM"
    Updated by FaroukM
    Thanks mate :)
