Altair RISE
Nominate Yourself Now!
how to set the number of core before running analysis
User: "zhuozhi"
Altair Community Member
Updated by zhuozhi
in the hyperform, when finishing the process setup, then right click and select 'run' to submit the calculation, However,the default cpu number is 1, how can i change the cpu number and speed up the calculation. thanks!
1 - 2 of 21
    User: "Chaitanya_Logade"
    Altair Employee
    Updated by Chaitanya_Logade
    Hi,
    You can go to Prefernces> HyperForm Settings. In the settings tab, you can find Radioss_Arguments. There you can change the -nproc value to the desired number.
    User: "zhuozhi"
    OP
    Updated by zhuozhi
    Hi,
    thanks for your reply
