in the hyperform, when finishing the process setup, then right click and select 'run' to submit the calculation, However,the default cpu number is 1, how can i change the cpu number and speed up the calculation. thanks!
You can go to Prefernces> HyperForm Settings. In the settings tab, you can find Radioss_Arguments. There you can change the -nproc value to the desired number.
Hi, You can go to Prefernces> HyperForm Settings. In the settings tab, you can find Radioss_Arguments. There you can change the -nproc value to the desired number.
thanks for your reply
