Error 185
*** ERROR # 185 ***
Invalid duplicated SPCD entry.
grid id = 47188
component = 3
load set id = 7
This error can happen when SPCD is applied to two GRIDs equivalenced
with use of PERBC, CONNECT or MPIN cards.
Goodmorning eveery body
I need a help for this error. I want to perform a FRF indicating my contraintes as surfaces, i am fully aware that SPCD contraintes must replicate SPC contraintes, and that is what i did, but it doesn't work.
what should i do? i share you the file .hm
thanks in advance
1 - 1 of
11
Hello Luca,
The model that you shared is just a modal analysis and it is running fine. Can you please share the .hm with the FRF setup?
In any case, try to review the surfaces that you are selecting to define the SPCD, maybe the interface nodes between them could have two SPCDs, leading to this error.
Thanks,
Vinicius Gomes
