*** ERROR # 185 ***
Invalid duplicated SPCD entry.
grid id = 47188
component = 3
load set id = 7
This error can happen when SPCD is applied to two GRIDs equivalenced
with use of PERBC, CONNECT or MPIN cards.
Goodmorning eveery body
I need a help for this error. I want to perform a FRF indicating my contraintes as surfaces, i am fully aware that SPCD contraintes must replicate SPC contraintes, and that is what i did, but it doesn't work.
what should i do? i share you the file .hm
thanks in advance
