Altair RISE
Nominate Yourself Now!
How to rectify the ERROR # 312 In static load case 1   the compliance is negative or large 1.07647e+008.  Optimization/buckling analysis cannot be performed.  due to possible rigid body mode.  INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED).
User: "yukesh.aero"
Altair Community Member
Updated by yukesh.aero
hello Every one ,
                           i am doing optimization in topology ,i got  some error in   below how to rectify that one , and also i check mesh connectivity and  rigid link and constraint all , but i have same error will be repeated how to rectify and give me  solution .
here i attached .hm file
*** ERROR # 312 ***
 *** SOME ERRORS WERE REPORTED DURING THE RUN,
 *** PLEASE VERIFY RESULTS AS THEY MAY BE INVALID.
1 - 5 of 51
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @yukesh.aero
    Check the loads and boundary conditions.
    If the constraints are applied on free nodes/temp nodes, solver exits with same error.
    Re-think about the Dofs constrained in your model. check the run with all Dofs constrained.
    Please note: Do not create multiple posts or status messages for the same question :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    User: "yukesh.aero"
    OP
    hello @Prakash Pagadala
                         i check constraints  correctly assigned , please check it .hm file here i attached , give me solution
    Sorry for the multiple post in same question wrongly upload its again and again
    Altair Employee
    Yukesh,
    Can you constraints in all directions and check?
    User: "yukesh.aero"
    OP
    @Prakash Pagadala
                            ok, its solving but as per bc  why its not solving and  is there any solution please give me to solve
    Altair Employee
    @yukesh.aero
    The model is free in the direction of loading which means infinite compliance. Constraint in Z direction (which is loading direction in your case) and check the results.
