Fixing interferences issues
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi all,
I'm performing a dynamic simulation using RADIOSS solver.
I'm creating this kind of model :
I used a COMPSH material law and an SH_ORTH property in order to model an 'equivalent material', with a 4 mm thickness.
When I run the analysis, I've issues regarding penetrations in my model. Nevertheless, when I want to fix them using the Penetration Check tool, elems are totaly deformed.
Could you please help me with this model ?
Best regards,
Raphael
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi,
    Please check the interface parameters you have used, especially the Gapmin value. The best is to specify a small Gapmin value.
    Which interface you are using, if type 7 use the recommended parameters.
    Also let me know whether you are trying for a self interface.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi George,
    Yes I'm using a type 7 interface with recommended parameters :
    Istf=4
    IGap=2
    INACTI=6
    Fric=0.1
    Gapmin=0.1
    So, do you mean that I've to increase GapMin parameter? How can I determine the good value ?
    I'm especially trying to stimulate this object impacting a rigid walk. I built this model using only 1 component, and I want to model the contact of this component itself. Am I in the good way ?
    Thanks
    Raphael
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi,
    You can try reducing the Gapmin value. Also instead of Type 7 you can try modelling it with Type 24 interface also.
    Please share the model file if the issue persist.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    I'll try right now this kind of interface.
    Do I have to try with the same parameters than Type 7 ?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
    Hi George,
    I tried with Type 7 and Type 24, and it still doesn't work.
    When I start the calculation, I always have a warning regarding initial penetration.
    Also, please find attached the concerned model.
    Thank you for your help
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi,
    Modified the contact parameters.
    Please try with the model attached.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi George,
    Thank you very much, the model is running as I wanted !
    Nevertheless, I've another question. How is it possible to orientate each surface of the model independently ?
    Thanks for your support
    Raphael
Welcome!
Welcome!
