Singular strain function
hiranwale_bharat
hiranwale_bharat Altair Community Member
edited October 2020 in Community Q&A
Hello Everyone,
I am trying to define a material by using Mathe card with stress stretch curve defined for tensile load.(in first quadrant).
I am getting an error saying ' CHEX element no. 123 has singular strain function.Please check material data.'
Can anyone tell me why this happened? Is there any remedy for this? Should i define my material curve with more no. of points?
Regards,
Bharat
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2016
    Hi Bharat,
    Can you share the entire .out file with us?
  • hiranwale_bharat
    edited March 2016
    Sorry prakash,
    I can't share the file directly to you. But I will update it tomorrow.
    regards,
    Bharat
  • hiranwale_bharat
    edited March 2016
    Hello Prakash,
    Sorry for late reply.
    As I said previously, I can't share the .out file, but please find the sna[ taken of it with this message. Hope it helps.
    Thanks and regards,
    Bharat
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited March 2016
    Hi,
    Send me the MATHE and TABLES1 card details from the deck
    Regards
    Rahul R
  • hiranwale_bharat
    edited November 2020
    Hello Rahul,
    Please find attached excel file for your perusal.
    It is Stretch stress curve.
    Regards,
    Bharat
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2016
    Hi Bharat,
    is it a true stress strain curve or a Engineering stress strain curve?
  • hiranwale_bharat
    edited March 2016
    Hello Prakash,
    it is true curve.
    Regards,
    Bharat
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2016
    Hi Bharat,
    The error points to a single element, I believe and its a combination of material model and mesh size.
    Can you remesh that particular element (element ID 343, increase the size of the element) in your model and try again.
  • Rahul Rajan_21763
    edited March 2016
    Hi,
    Can you please add the below Debug card and re-run the job
    DEBUG,HEPPPRTC,1
    Please send me the .out file after running with this card
    Regards
    Rahul R
  • hiranwale_bharat
    edited April 2016
    Hello Rahul,
    Sorry for such a late reply.
    I tried the Debug command on a different model which was giving same error ,but no use. I even tried changing that particular elements length , but that did not help either.
    Thanks And regards,
    Bharat
  • Rahul Rajan_21763
    edited April 2016
    You can try specifying only C10 value as 0.36, NA as ‘1’ and remove the TABLES1 card from MATHE card
    Regards
    Rahul R
  • hiranwale_bharat
    edited April 2016
    Hello Rahul.
    I tried as per your instructions.
    Run was complete but results are not as I had expected. Disp. Is 3 times higher than actual diap.
    Thank you and regards
    Bharat
Welcome!
Welcome!
