Optistruct Solver View doesn't show up
User: "MaxB"
Altair Community Member
Updated by MaxB
Hello,
i am new to Hypermesh/Optistruct and i started my training with a youtube tutorial about the topology optimization of a bridge (https://www.youtube.com/watch?v=RcbsMz81bPs).
so here is my problem:
after setting up the model i hit the optistruct button but nothing happens. In the bottom left corner of the hypermesh window there is some action going on but after a few seconds it says 'ready' and no window of optistruct or the optistruct solver view is showing up. I guess optistruct never started the analysation process. But there is no error.
Can someone help me with this? I uninstalled the application and installed it again with a new downloaded file but this did not solve the problem. I am working with the student version of HyperWorks 2019.
Thanks in advance,
Max
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Please don't use any special character while saving file or during analysis. I see you used brA1/4et as the name.....Just save file as bracket. It should run the analysis.
    User: "Prathamesh1225"
    Updated by Prathamesh1225
    Hello,
    I didn't use special characters, I am using hyperworks 2019 - student edition. When I click on Analysis>optistruct, .fem file is created and it shows ready at bottom, solver view don't show up. I read many posts related to this issue, and below are the things that I tried -
    1. Avoid using special characters
    2. use .fem extension.
    3. re-install the software
    4. Change read only directories to not read only in program files folder.
    Please help me with this
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    i would avoid running in folders and using filenames with 'space' on it.
    Can you rename your fem file and try running in somewhere like: 'C:/temp/carm.fem'?
    Hey Adriano,
    I tried to save it in C drive, It didn't work.
    Altair Employee
    are you sure there`s no error message in the bottom left when you try to run your model?
