🎉Community Raffle - Win $25
Join and Win
About PSIM F28335 code generator
User: "Adam Wu"
Altair Community Member
Updated by Adam Wu
Hi everyone,
I have encountered some issues with the code generator for F28335 when simulating the circuit. The error message is as follows:
Error Message:
Element: DLL_EXT_ESB        Name: MainCCode
ERROR: maybe missing ';' before '*'
ERROR: syntax error before or at line 135 in file 'C:\Altair\PSIM_2022.1\PsimTmp\sE3501.cxx'
  ==>:     DefaultType    fADC1_8, fVdc*, fZOH1, fADC1_1, fADC1_9;
  BUG:     DefaultType    fADC1_8, fVdc*<== ???
ERROR: variable 'fZOH1' not defined
  BUG:     DefaultType    fADC1_8, fVdc*, fZOH1<== ???
ERROR: variable 'fADC1_1' not defined
My PSIM version is PSIM professional 2022.1.0.8.
Thank you very much for taking the time to respond.
1 - 2 of 21
    User: "Rhonda_20369"
    New Altair Community Member
    Updated by Rhonda_20369
    Hi, Adam,
    Are you running simulation of one of the PSIM examples? Which one?
    Have you built your own PSIM schematic? Please attach it here or create a support request.
    User: "Adam Wu"
    OP
    Updated by Adam Wu
    Hello, everyone.
    I just accidentally discovered that one of my command voltage sources, called Vdc*, was working fine before I added the 28335 module. However, once I added it, the error message above appeared.
    I'm sharing this error message with all of you, and I hope everything goes well! Thank you for responding, Rhonda."
