🎉Community Raffle - Win $25
Join and Win
Maximum principle stress and signed von-mises stress in radioss
User: "Rachit Semalty"
Altair Community Member
Updated by Rachit Semalty
Hi. I want to plot maximum principle stress, elastic strain energy and signed von-mises contours for Tetra4 meshed components. Which card should I use?
Regards,
Rachit
1 - 4 of 41
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    I don't know about ESE
    For the priniciples and signed von mises you can request:
    /ANIM/BRICK/TENS/STRESS/ALL
    /ANIM/BRICK/TENS/STRAIN/ALL
    with an /ANIM/DT card
    if you are using /ANIM output
    or
    /H3D/SOLID/TENS/STRESS
    /H3D/SOLID/TENS/STRAIN
    with an /H3D/DT
    if you are using /H3D output
    OP
    Hello Paul. Thanks for your reply. But I am still not able to get principle stresses. Maybe the above card works for brick elements only.
    Regards,
    Rachit
    User: "PaulAltair"
    Altair Employee
    Regards,
    Rachit
    Are you looking under the correct entry? 'Strs Intg Point111' if you are using Anim file (it will be separate to 'Stress' if you are still asking for 'ELEM' stress too. It should definitely be working for Tetras
    OP
    Hi Paul. Thanks for your reply. Yes you are correct, 'Strs Intg Point111' entry has stress values.
    For ESE, we may use /Anim/Elem/EINT. It gives internal energy, which should be same as strain energy.
    Regards,
    Rachit
