1 - 5 of
51
Thank you very much for your interest Prakash Pagadala;
no I have not interface type 2 in my model, here the joint 0001.out file
VARIABLE SAVED ON ANIMATION FILES (1: YES) :
PLASTIC STRAIN. . . . . . 1
DENSITY (SOLID ONLY). 0
SPECIFIC ENERGY . . . . . 1
HOURGLASS ENERGY. . . . . 1
TEMPERATURE (SOLID ONLY). 0
THICKNESS (SHELL ONLY). 0
PRESSURE (SOLID ONLY). 0
VON MISES . . . . . . . . 1
TURBULENT ENERGY (FLUID). 0
TURBULENT VISCOSITY(FLUID) 0
VORTICITY (FLUID) . . . . 0
VECTOR SAVED ON ANIMATION FILES (1: YES) :
VELOCITY VECTOR . . . . . 1
DISPLACEMENT VECTOR . . . 0
ACCELERATION VECTOR . . . 0
CONTACT FORCES. . . . . . 1
INTERNAL FORCES . . . . . 0
EXTERNAL FORCES . . . . . 0
SECTION RBY RWALL FORCES. 1
ROTATIONAL VELOCITY VECTOR 0
CONTACT PRESSURE (VECTORS) 0
SHELL TENSOR SAVED ON ANIMATION FILES (1: YES) :
MEMBRANE STRESS . . . . . 0
BENDING STRESS(MOMENT/T^2) 0
UPPER LAYER STRESS. . . . 0
LOWER LAYER STRESS. . . . 0
MEMBRANE STRAIN . . . . . 0
CURVATURE . . . . . . . . 0
UPPER LAYER STRAIN. . . . 0
LOWER LAYER STRAIN. . . . 0
NODAL MASS SAVED ON ANIMATION FILES (1: YES) : 1
KEEP DELETED ELEMENT (1: YES) : 0
INITIAL TIME STEP. . . . . . . . . . . . . . . . 0.000000
MAXIMUM TIME STEP. . . . . . . . . . . . . . . . 0.1000000E+31
PARALLEL ARITHMETIC ON
ALE GRID FORMULATION
NUMBER OF INTERFACES TO BE ELIMINATED. . . . . . 0
NUMBER OF SOLID ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF QUAD ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF SHELL ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF TRUSS ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF BEAM ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF SPRING ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF SH_3N ELEMENT BLOCKS TO BE ELIMINATED 0
NUMBER OF SPH PARTICLES BLOCKS TO BE ELIMINATED 0
NUMBER OF RIGID LINKS. . . . . . . . . . . . . . 0
NUMBER OF ALE LINKS. . . . . . . . . . . . . . . 0
NUMBER OF NEW BOUNDARY CONDITIONS. . . . . . . . 0
29/01/2015
SENSOR NUMBER 1 ACTIVATED AT TIME 0.00000E+00
SENSOR NUMBER 4 ACTIVATED AT TIME 0.00000E+00
SENSOR NUMBER 7 ACTIVATED AT TIME 0.00000E+00
SENSOR NUMBER 10 ACTIVATED AT TIME 0.00000E+00
SENSOR NUMBER 15 ACTIVATED AT TIME 0.00000E+00
CYCLE TIME TIME-STEP ELEMENT ERROR I-ENERGY K-ENERGY T K-ENERGY R EXT-WORK MAS.ERR
0 0.000 0.2546E-04 NODE 67073756 0.0% 0.000 NaN 0.000 0.000 16.90
ANIMATION FILE: siege_complet_90A001 WRITTEN
RESTART FILES: siege_complet_90_0001_[0001-0001].rst WRITTEN
** CPU USER TIME **
#PROC CONT.SORT CONT. F ELEMENT KIN.COND. INTEGR. I/O TASK0 ASSEMB. RESOL
1 .5148E+00 .1560E-01 .1685E+01 .0000E+00 .4680E-01 .2590E+01 .0000E+00 .7800E-01 .8689E+01
** CUMULATIVE CPU TIME SUMMARY **
CONTACT SORTING.............: .5148E+00 5.92 %
CONTACT FORCES..............: .1560E-01 0.18 %
ELEMENT FORCES..............: .1685E+01 19.39 %
KINEMATIC COND..............: .0000E+00 0.00 %
INTEGRATION.................: .4680E-01 0.54 %
ASSEMBLING..................: .7800E-01 0.90 %
OTHERS (including I/O)......: .6349E+01 73.07 %
TOTAL.......................: .8689E+01 100.00 %
** MEMORY USAGE STATISTICS **
TOTAL MEMORY USED .........................: 2580 MB
MAXIMUM MEMORY PER PROCESSOR...............: 2580 MB
MINIMUM MEMORY PER PROCESSOR...............: 2580 MB
AVERAGE MEMORY PER PROCESSOR...............: 2580 MB
** DISK USAGE STATISTICS **
TOTAL DISK SPACE USED .....................: 1192654 KB
ANIMATION/TH/OUTP SIZE ....................: 152904 KB
RESTART FILE SIZE .........................: 1039750 KB
ELAPSED TIME = 18.59 s
0:00:18
NORMAL TERMINATION
TOTAL NUMBER OF CYCLES : 1
Hi Mounir,
Do you have a type 2 interface in your model?
if yes, please change Spotflag=1.
check if there are any initial penetrations, in such case, if you have /DT/NODA/CST in Engine it is recommended to remove it.
Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
