Error off added mass
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello everyone ;
I am trying to run a calculation RADIOSS, but the calculation is stopped before the first movie, and there a mass addition on the node that are normal and connected
thank you in advance for your help
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2015
    Hi Mounir,
    Do you have a type 2 interface in your model?
    if yes, please change Spotflag=1.
    check if there are any initial penetrations, in such case, if you have /DT/NODA/CST in Engine it is recommended to remove it.
    Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same http://www.altairhyp...ortProduct.aspx
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Thank you very much for your interest Prakash Pagadala;
    no I have not interface type 2 in my model, here the joint 0001.out file
     VARIABLE SAVED ON ANIMATION FILES (1: YES) :
          PLASTIC STRAIN. . . . . .     1
          DENSITY     (SOLID ONLY).     0
          SPECIFIC ENERGY . . . . .     1
          HOURGLASS ENERGY. . . . .     1
          TEMPERATURE (SOLID ONLY).     0
          THICKNESS   (SHELL ONLY).     0
          PRESSURE    (SOLID ONLY).     0
          VON MISES . . . . . . . .     1
          TURBULENT ENERGY (FLUID).     0
          TURBULENT VISCOSITY(FLUID)    0
          VORTICITY (FLUID) . . . .     0
     VECTOR SAVED ON ANIMATION FILES (1: YES) :
          VELOCITY VECTOR . . . . .     1
          DISPLACEMENT VECTOR . . .     0
          ACCELERATION VECTOR . . .     0
          CONTACT FORCES. . . . . .     1
          INTERNAL FORCES . . . . .     0
          EXTERNAL FORCES . . . . .     0
          SECTION RBY RWALL FORCES.     1
          ROTATIONAL VELOCITY VECTOR    0
          CONTACT PRESSURE (VECTORS)    0
     SHELL TENSOR SAVED ON ANIMATION FILES (1: YES) :
          MEMBRANE STRESS . . . . .     0
          BENDING STRESS(MOMENT/T^2)    0
          UPPER LAYER STRESS. . . .     0
          LOWER LAYER STRESS. . . .     0
          MEMBRANE STRAIN . . . . .     0
          CURVATURE . . . . . . . .     0
          UPPER LAYER STRAIN. . . .     0
          LOWER LAYER STRAIN. . . .     0
     NODAL MASS SAVED ON ANIMATION FILES (1: YES) :    1
     KEEP DELETED ELEMENT (1: YES) :    0
     INITIAL TIME STEP. . . . . . . . . . . . . . . .   0.000000
     MAXIMUM TIME STEP. . . . . . . . . . . . . . . .  0.1000000E+31
     PARALLEL ARITHMETIC ON
     ALE GRID FORMULATION
     NUMBER OF INTERFACES TO BE ELIMINATED. . . . . .        0
     NUMBER OF SOLID  ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF QUAD   ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF SHELL  ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF TRUSS  ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF BEAM   ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF SPRING ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF SH_3N  ELEMENT BLOCKS TO BE ELIMINATED        0
     NUMBER OF  SPH PARTICLES BLOCKS TO BE ELIMINATED        0
     NUMBER OF RIGID LINKS. . . . . . . . . . . . . .        0
     NUMBER OF ALE LINKS. . . . . . . . . . . . . . .        0
     NUMBER OF NEW BOUNDARY CONDITIONS. . . . . . . .        0
     29/01/2015
     SENSOR NUMBER        1 ACTIVATED AT TIME  0.00000E+00
     SENSOR NUMBER        4 ACTIVATED AT TIME  0.00000E+00
     SENSOR NUMBER        7 ACTIVATED AT TIME  0.00000E+00
     SENSOR NUMBER       10 ACTIVATED AT TIME  0.00000E+00
     SENSOR NUMBER       15 ACTIVATED AT TIME  0.00000E+00
     CYCLE    TIME      TIME-STEP  ELEMENT          ERROR  I-ENERGY    K-ENERGY T  K-ENERGY R  EXT-WORK MAS.ERR
         0   0.000      0.2546E-04 NODE    67073756   0.0%   0.000             NaN   0.000       0.000       16.90
         ANIMATION FILE: siege_complet_90A001 WRITTEN
         RESTART FILES: siege_complet_90_0001_[0001-0001].rst WRITTEN
                               ** CPU USER TIME **
     #PROC  CONT.SORT  CONT. F   ELEMENT  KIN.COND.  INTEGR.    I/O     TASK0     ASSEMB.   RESOL
       1   .5148E+00 .1560E-01 .1685E+01 .0000E+00 .4680E-01 .2590E+01 .0000E+00 .7800E-01 .8689E+01
                       ** CUMULATIVE CPU TIME SUMMARY **
     CONTACT SORTING.............: .5148E+00     5.92 %
     CONTACT FORCES..............: .1560E-01     0.18 %
     ELEMENT FORCES..............: .1685E+01    19.39 %
     KINEMATIC COND..............: .0000E+00     0.00 %
     INTEGRATION.................: .4680E-01     0.54 %
     ASSEMBLING..................: .7800E-01     0.90 %
     OTHERS (including I/O)......: .6349E+01    73.07 %
     TOTAL.......................: .8689E+01   100.00 %
                       ** MEMORY USAGE STATISTICS **
     TOTAL MEMORY USED .........................:     2580 MB
     MAXIMUM MEMORY PER PROCESSOR...............:     2580 MB
     MINIMUM MEMORY PER PROCESSOR...............:     2580 MB
     AVERAGE MEMORY PER PROCESSOR...............:     2580 MB
                       ** DISK USAGE STATISTICS **
     TOTAL DISK SPACE USED .....................:  1192654 KB
     ANIMATION/TH/OUTP SIZE ....................:   152904 KB
     RESTART FILE SIZE .........................:  1039750 KB
     ELAPSED TIME     =         18.59 s
                              0:00:18
         NORMAL TERMINATION
         TOTAL NUMBER OF CYCLES  :       1
  • gopal_rathore
    gopal_rathore Altair Community Member
    edited May 2016
    Hi,
    Was the above mentioned problem solved. I am getting the same issue where I can see high values for the nodal time steps in order of 1e 06. I have also used admas option in the input. Only one animation file is getting generated and the getting terminated with time step of 1e 06.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Hi gopal,
    Is your added mass supprted via Rbody?
    How about inertia values?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    can you share the engine (_0001.rad) file
Welcome!
Welcome!
