Motors with different paramters
I have a circuit of an induction machine that i want to start using a star/delta switch. The thing is i want to find the time that i should go from star to delta connection by having the least amount of energy losses…I made up te circuit so it can automatically calculate them and i want to run it with various numbers for the star/delta alternation so i can figure what value is the more profitable…Can i ,somehow, run the circuit for many values and take multiple simview files with an automatic procedure? I hope my bad english gave you an understnading of my problem!
1 - 1 of
11
Yes the parameter sweep element or running from the command line will allow you to do this.
Parameter sweep is section 6.8 of the user manual
Command line simulation is section 2.9.2 of the user manual
