Density user defined equation
Altair Forum User
Altair Forum User
Altair Employee
edited November 2020 in Community Q&A
I am learning CFD and I have a problem that has density as a function of Temperature and Pressure.  To start, I wrote a user defined function (usrMyDensity.c) where density is only a function of temperature (linear equation).  I was able to compile the function and call it in my input file, but when i run a simple analysis (internal flow with constant temperature at the walls), i am not able to plot density in FieldView.  I'm assuming that i'm not using the correct problem set up.
I know that it is using the complied user function because initially it was giving me an error of negative density, which i fixed with an if statement in my user function.
Any advice will be greatly appreciated.
thank you for your time and patience
Welcome!
Answers
  • acupro
    acupro
    Altair Employee
    edited April 2018
    In order to see contours of density, you'll need to request Derived Quantity Output, which is a separate command in the input file.  The default setting is output_frequency = 0, meaning derived quantity output will not be written.  You'll probably want to change that so the output_frequency is the same as you request for Nodal Output.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    acupro,
    thank you very much, that did it!!!
    I have a followup question regarding compiling C files for a Acusolve user defined function.  if you take a look at the attached doc on my original question (usrMyDensity.c), you'll see that it is a very simple linear equation.  I kept it simple so I could get familiar with compiling user defined functions and calling them in the input file.  However, I now want to create a user defined function that interpolates the density between temperature and pressure.  I wrote a very crude C++ program in Visual Studio to open a .txt file, find pressure and temperatures, and interpolate the density.  I run this file using Visual Studio and it works.  in Visual Studio, to open and read a .txt file, i included fstream.h (#include <fstream>).
    in Acusolve, I want to start by having the user-defined function open the .txt file and read one value (baby steps), but when i try to compile, it is giving me lots of errors.  in the C code, how do I include the fstream.h needed to open and read text files?
    thank you very much
  • acupro
    acupro
    Altair Employee
    edited April 2018
    Probably better to contact support at hwsupport@altair.com for those details.  By the way, if you're looking for ideal gas density - a function of absolute temperature and pressure - that is already supported in AcuSolve.
Welcome!
Welcome!
