Altair RISE
Nominate Yourself Now!
FSTOSZ Error #13: DLINK dependent DESVAR repeated in input data
User: "Turbokraken"
Altair Community Member
Updated by Turbokraken
Hello Everyone,
Here I am yet again with another OptiStruct issue I need your support for.
I am currently doing a multi-Phase Composite optimisation and I encountered a Problem with Phase 2: Size Optimisation.
When I activate the SDTOSZ command during my FreeSize optimisation, I receive faulty sizing-data. If I plug the xx.sizing.fem data back into HyperMesh and run a 'Check', I receive the following error message:
Error #13: DLINK dependent desvar repeated in input data. (17x)
This unfortunately happens in all other FSTOSZ data as well. I could not find any solutions or a workaround for this.
I would be very grateful if you could perhaps help me with this issue :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Best Regards and a good week,
Lennart
1 - 10 of 101
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Lennart,
    Can you sahre the complete .out file, please?
    Altair Employee
    also, do you have Ply balance constraint on your laminate?
    If yes can you remove the same and try again?
    User: "Turbokraken"
    OP
    Hi,
    please find attached the OUT-Data, however there is not a lot written in it.
    I made another test with a ply Balance constraint and appearently the Problem only appears when I do have a ply Balance constraint in there.
    Is there a Workaround for when I do not use a ply Balance constraint?
    Best Regards,
    Lennart
    Altair Employee
    Hi,
    yes, this is a known issue with Ply balance constraint.
    If possible, please share an example model file to test at our end.
    User: "Turbokraken"
    OP
    Hi Prakash,
    Thank you for your help. I looked into the data again and I noticed that I did not use a Balance constraint. What I used was a constraint that binds the thickness of two plies.
    If I use it, it works. if I don't it does not.
    Regards,
    Lennart
    Altair Employee
    Can you share a screenshot of the card?
    User: "Turbokraken"
    OP
    Hi,
    please find attached the Card with all relevant info on the Balance-Constraint.
    Best Regards,
    Lennart
    Altair Employee
    Hi,
    Yes, the issue is with Ply balance. If you have ply balance on the orientations other than 45 and -45, the analysis stops with that error.
    User: "Turbokraken"
    OP
    Hi,
    Thank you for your answer. Is this the way it is intended to be or will there be a patch in the future to include all other orientations except +/-45°?
    Best Regards,
    Lennart
    Altair Employee
    HI,
    Yes, this is the way it is for now. But, enhancement receipt is available to include other orientations as well :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
