Altair RISE
Nominate Yourself Now!
Export results from cluster to Ensight
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I was sent here coming from this topic right here:
I ran a case on our cluster and now want to export the results to Ensight format to postprocess in Hyperview, but AcuOut does not seem to find the results. I tried to open the case (.acs file) in Acusolve and export  it using AcuOut. I assume this way only works right after a case as been solved locally. However, I need to export the files coming from another machine. How can one do this? By the way, I can't just open the .log file in Hyperview. I run shear thinning fluid simulations and when I try to open these in HV via the logfile, I get an error saying 'Time does not match' and I can't display all the time steps. Also, velocity and pressure are the only displayed values this way, although I set more than these. So this way is not an option, unfortunately.
