Contact analysis
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear All,
how can i resolve this error.?
1 - 13 of 131
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    Hi @Ganesh Munge
    Is your problem a case of large deformation? What is the contact interface you defined? And at what load step your solution is being non-covergent? And which error value is resulting in non covergence?
    Altair Employee
    OP
    Dear Nachiket,
    Thanks for support,
    Issue was of equivalence. I forgot to do the same. Now it is sorted out.
    Altair Employee
    OP
    Dear @Prakash Pagadala, @Nachiket Kadu
    Suppose
    case 1:
    I have an interference of 80 microns in shaft and housing and
    case 2:
    if i have gap of 80 micron bet same.
    how can i define frictional contact contact between above cases.
    can you revert with when to define search distance and when to define clearance. also, how to choose track
    @Ganesh Munge
    Search distance is used define contact condition between slave and master, as in only those nodes will be in contact which satisfy the search distance criteria. Clearance defines the the distance the master and slave need to move so as to be in contact.
    Altair Employee
    OP
    If I have interference, What should i use clearance or search distance?
    @Ganesh Munge
    I am not sure about previous version but negative clearance in 2017.3 is defines inititial penetration. @Prakash Pagadala correct me if i am wrong!!
    Is your geometry in base size or tolerances are already included?
    @Ganesh Munge
    refer this
    Altair Employee
    OP
    geometry is with tolerances,
    these parts are in interference fit (image1) of 80 microns, I used clearence of -0.090. but after completion of simulation it is showing gap like in image 2
    image.png.785ebd6e4f9be52617cf7446d7471f30.pngimage.png.ec6c3bf5f73d21b273b676645573cc86.png
    <?xml version="1.0" encoding="UTF-8"?>image.png.785ebd6e4f9be52617cf7446d7471f30.png<?xml version="1.0" encoding="UTF-8"?>image.png.ec6c3bf5f73d21b273b676645573cc86.png
    As in no contact u mean to say?
    Altair Employee
    OP
    These are in contact,
    Outer ring of bearing is press fitted into the housing with the above mentioned interference value.
    as per physics, housing should expand and outer ring should contact.
    here outer ring is getting contracted and creating gap between housing and outer ring as i showed above in Image 2.
    my question is why it is showing gap?, outer ring should touch housing inner surface.
    That gap which you are mentioning you checked distance between those node?
    Altair Employee
    OP
    HI,
    Positive CLEARANCE is equal to the distance that slave and master surfaces have to move towards each other in order to close the contact,
    Negative CLEARANCE indicates contacting bodies have initial penetrations and is equal to resolving interference-fit / press-fit problems
    SRCHDIS is important in both cases.
