HM to abaqus
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello, help me please
what i'm doing
1st stl export,  mesh create
2nd stl export,  mesh create
then i need 2 meshes in abaqus (part1 , part2)
export to abaqus - all
abaqus: import model
AbaqusException: in keyword *ELEMENT, file 'few.inp', line 959300: Period cannot be used within set, surface, orientation, instance, and assembly names in a model defined in terms of an assembly of parts This occurred while parsing the input file. Run the input file through the batch pre-processor to check for syntax errors.
Please say how to solve it,
Thanks
1 - 8 of 81
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    'STL' is NOT FE meshing !!!
    Start your profile with Abaqus within Hypermesh and begin to make your mesh on it.
    Altair Employee
    OP
    Sorry , but shrink wrap mesh works well
    User: "pohan"
    Updated by pohan
    @evgenabaqus
    I have the same question! Did you get the answer?
    Altair Employee
    OP
    @evgenabaqus
    Can you explain your question, please?
    User: "pohan"
    Updated by pohan
    Hi
    I try to export a model with 2 different components with mesh, but when I import it in Abaqus they are all in one part.
    How can I import them as 2 different parts
    Altair Employee
    OP
    @pohan
    Can you share the HM version, update details and Abaqus version details, please?
    User: "pohan"
    Updated by pohan
    Hi
    I use HM 2017.2 and Abaqus 6.13-4
    I have a model with 2 components in HM. I used HM/ABAQUS standard 2D. I exported my model as *.inp file but when I imported it in ABAQUS it combined 2 components into 1 part instead of 2 parts
    User: "Marcin Kneć_21510"
    Updated by unknown
    Hi I found what is the problem with this error.
    The topic is old but the problem remains (I use 2021.2)
    Spend an hour to resolve - so maybe other users will find this hint useful :)
    Your model may be fine.
    Problematic is a dot "." inside a .inp file
    when you change it to "vol001" instead of "vol001.1" (or anything else) but without that dot import in ABAQUS will be fine.
    When this is happend.
    During a creating many components in HyperMesh Components the name with "."  may appear.
    So just change the name in HyperMesh and remove the dot.
