HM to abaqus
Altair Forum User
Altair Forum User
edited February 2022 in Community Q&A
Hello, help me please
what i'm doing
1st stl export,  mesh create
2nd stl export,  mesh create
then i need 2 meshes in abaqus (part1 , part2)
export to abaqus - all
abaqus: import model
AbaqusException: in keyword *ELEMENT, file 'few.inp', line 959300: Period cannot be used within set, surface, orientation, instance, and assembly names in a model defined in terms of an assembly of parts This occurred while parsing the input file. Run the input file through the batch pre-processor to check for syntax errors.
Please say how to solve it,
Thanks
Welcome!
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited November 2017
    'STL' is NOT FE meshing !!!
    Start your profile with Abaqus within Hypermesh and begin to make your mesh on it.
  • Altair Forum User
    Altair Forum User
    Sorry , but shrink wrap mesh works well
  • pohan
    pohan Altair Community Member
    edited October 2018
    @evgenabaqus
    I have the same question! Did you get the answer?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    @evgenabaqus
    Can you explain your question, please?
  • pohan
    edited October 2018
    Hi
    I try to export a model with 2 different components with mesh, but when I import it in Abaqus they are all in one part.
    How can I import them as 2 different parts
  • Altair Forum User
    Altair Forum User
    edited October 2018
    @pohan
    Can you share the HM version, update details and Abaqus version details, please?
  • pohan
    edited October 2018
    Hi
    I use HM 2017.2 and Abaqus 6.13-4
    I have a model with 2 components in HM. I used HM/ABAQUS standard 2D. I exported my model as *.inp file but when I imported it in ABAQUS it combined 2 components into 1 part instead of 2 parts
  • Marcin Kneć_21510
    Marcin Kneć_21510 Altair Community Member
    Hi I found what is the problem with this error.
    The topic is old but the problem remains (I use 2021.2)
    Spend an hour to resolve - so maybe other users will find this hint useful :)
    Your model may be fine.
    Problematic is a dot "." inside a .inp file
    when you change it to "vol001" instead of "vol001.1" (or anything else) but without that dot import in ABAQUS will be fine.
    When this is happend.
    During a creating many components in HyperMesh Components the name with "."  may appear.
    So just change the name in HyperMesh and remove the dot.
Welcome!
Welcome!
