HM to abaqus
Hello, help me please
what i'm doing
1st stl export, mesh create
2nd stl export, mesh create
then i need 2 meshes in abaqus (part1 , part2)
export to abaqus - all
abaqus: import model
AbaqusException: in keyword *ELEMENT, file 'few.inp', line 959300: Period cannot be used within set, surface, orientation, instance, and assembly names in a model defined in terms of an assembly of parts This occurred while parsing the input file. Run the input file through the batch pre-processor to check for syntax errors.
Please say how to solve it,
Thanks
I have the same question! Did you get the answer?
Can you explain your question, please?
Hi I found what is the problem with this error.
The topic is old but the problem remains (I use 2021.2)
Spend an hour to resolve - so maybe other users will find this hint useful
Your model may be fine.
Problematic is a dot "." inside a .inp file
when you change it to "vol001" instead of "vol001.1" (or anything else) but without that dot import in ABAQUS will be fine.
When this is happend.
During a creating many components in HyperMesh Components the name with "." may appear.
So just change the name in HyperMesh and remove the dot.
'STL' is NOT FE meshing !!!
Start your profile with Abaqus within Hypermesh and begin to make your mesh on it.
