🎉Community Raffle - Win $25
Join and Win
constraints 6 DOF
MattiaUser: "Mattia"
Altair Community Member
Updated by Mattia
Hi everybody,
does anyone know why in Hypermesh software constraints allow 6 degrees of freedom on a solid mesh model, if for a solid mesh only 3 degrees of translational freedom are allowed?
Thank you
1 - 2 of 21
    tinhUser: "tinh"
    Updated by tinh
    If you constraint 6 dofs of solid element you will see a warning message says that it affects to only 3 dofs. If nodes are shared among solid elem and shell/beam elem, it will affects to 6 dofs. Hypermesh is designed that in order to be useful in many situations.
    OP
    Updated by Mattia
    ok, thank you tinh
